turbosax2
Moderator
- 4,483
- 674
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
Can anyone tell me why Mitsubishi places the PCV nipple where they do on the intake manifold?
I'm installing a vacuum block onto my Evo III intake manifold that is fed from the plenum. This leaves me with the option of plumbing the PCV line to the vacuum block, or leaving it in its current location. The green line above shows the "hump" where the PCV inlet connects to each of the four runners internally, so I'm not sure how moving it the plenum/vacuum block would really be that different. I've been trying to think of pros and cons to each location, but the only one I've been able to come up with is that if I leave it in the stock position, any oil that gets through my catch can will only contaminate the runners in the intake manifold rather than contaminating everything fed by the vacuum block.
Opinions and ideas welcomed!
