parts interchangeability
MattB
Feb 10, 2008
Norfolk, Nebraska
OK im working on my friend's 1991 Eagle Talon TSI. I did a search and i didn't find any set in stone anwsers for my ?'s. So first off the Ignition coils tested bad and i was wondering if the coil from a non turbo car will work the same. Also the ISC is bad and and i would like to know if that part is interchangeable from a non turbo car to. And is there any cutoff on model years for these parts (i.e. 2g parts wont work on a 1g)Any help would be great thaks.
iscs are interchange able for 1g turbo and none the coil im pretty sure its the same 95 and up is no good
If I am not mistaken the coil packs you need are from 91-94 and I do belive the n/t will interchange. 90 coil packs will not work with out modifacion youll have to research that.
  • Wanted 6 bolt NT water pipe
    • chrisman287
