Parking + Curb = no vacuum
graf703
97
Sep 5, 2004
Minneapolis, Minnesota
So I was parking my car after its block and a half drive to school and I scraped the front end into the curb, just a little bit. The car started idleing really rough. Vacuum is about 10 mm. What could it have hitto make the vacuum go bad? The intercooler is to far back, right? I haven't had a chance to really get into it, there is snow on the ground and I've got class. Any suggestions on where to start?
so i got a chance to look at it. Whats the black plastic box between the intercooler and the turbo? Its broken, i taped up the crack but it won't hold boost. How unsafe is this to drive? Any cheaper fixes than getting a new one? Can I seal off the outlet to the box part and keep the plastic piping? (the crack is on the box) Thanks!
That black plastic box is a surge chamber, basicly an open space to help absorb shock in the intake system. With it broken you are going to have a major boost leak which will damage the engine if left unfixed.
You can find aftermarket pieces to replace this broken pipe. They are often called LIC or S-pipes, I know RRE has them as thats whats on my car, but I am sure other shops have simular products.
