Palm "N" Stein Help needed!!!
97ClipseDSM
1,024
Feb 24, 2004
Stafford, Virginia
Hey i have a Palm M100 Logger and im running the Palm "N" Stein software. I can log the error codes or clear them but thats pretty much all i can do. I have selected the OBDII interface, checked off fast log and charts, etc. However when I Press F1 to Log the following (RPM, Timing, Coolant (my coolant gauge is not that great), O2V, etc...when i try to log these, instead it will just randomly log numbers that are not even accurate. They always end up around 40 and then start over at 1. When i press F3, it says something like "not logging" or something. I am having trouble logging anything. For those that run this software, in what steps do you log and how the hell do you log. I thought it would be something simple like just choose what you want to log and itll start logging but it just logs random numbers that have nothing to do with my vehicle..almost like samples. :notgood:
It will do that 40 to 0 thing when it's in Test Mode. Uncheck this box.
From this screen, when I want to log, all I check is;
OBD-II...
Digital Mode
Fast Log Mode
Auto Save and Play
Then I hit the up button (m100 too), select what I want to log, then hit F1.
OBD-II...
Digital Mode
Fast Log Mode
Auto Save and Play
Thanks alot for your help turbolarry. I havnt had time to mess with the logger yet because ive been working but once i get some time, ill definitely try out what you said. Hopefully that will work.
