P0505 error?
OneFastEclipse said:
I am getting a check engine light for Idle Control system. What could be causing this and how do I fix it? Thanks!
try www.vfaq.com they have everything you need to know about 1g and 2g dsms plus they got a faq about obd 2 and 1 codes so you can look it up in there :thumb: :dsm:
luv2rallye said:
Usually means the Idle Air Control Motor is bad.
Yeah. I got the same code and had to replace the IAC. It's the frikkin third one in two years :thumbdown .
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
