Error P0505 - Problem with Revised Version IAC ISC I purchased
1998SilverGSX
Dec 29, 2003
NYC, New York
Hey everyone, I need some help.
I recently ran into some problems with my car. I keep getting a CEL, P0505. I figure out by process of elimination that it has to be my ISC, cuz I pretty much check everything else, ie vacuum leaks, biss screw, tps, fiav, throttle cable. I even tested the ISC on my car and the coils all were around ~33 ohms. Unfortunately, I have the rare case of a ISC testing out perfectly, but I'm still getting having ISC problems; my RPM's drop when I turn on my AC. :(
In any case, I go on ebay and purchase another ISC (a revised black version which I hear is less prone to go bad) The auction clearly stated that it was tested and it worked on the seller's vehicle. I received the ISC yesterday and tested it, and the coils all test at ~40 ohms. WTF The seller claims this is due to the ambient temperature, but what's important is that is it consistently the same ohm value. Is this true? From all the research I've done, I am highly doubtful that this piece is good, but I'm not 100% sure, since it's the newer revised black version.
Please help. :confused:
Ernie
damn bro you just explained my problem in every way....I have the exact same problem when i say exact i mean word by word....i got on ebay too and still the same...im gonna go head and clean the throttle body and see what happens i guess....but my RPM is pretty much ok at 800-900 rpm...
paul s said:
I have purchased the new(black) ISC from the dealer and the resistance is also around 40ohm, it works good and the car idles OK..
My local dealer quoted me $328 fuucckkkk tthhaaaattttt....
my car too every couple of weeks throws me a p0505 CEL, the last time i got the CEL was becuase the connector was very loose and didnt "click" when you pluged it onto the ISC (worn out from swapping in and out Throttle bodies) , check that first it could save you a lot
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
