Overspray panels
Any type of rubbing with discolor the plastic/rubber. think of re spraying it with SEM trim black after.
As for taking off the paint, you can gently scrape (at 90° with a razor blade) and finish it with a rag with a bit of paint thinner. Be sure to protect the panel/paint next to it.
Ive done this im painting mine i do have clips in case i brake mine when i pull the trim off. The easiest way maybe to mask it off, get some black paint, and touch it up with a small paint brush.
