gst1997turbo
- 0
- Nov 2, 2005
Springfield,
Louisiana
Well I purchased a 1997 GST Turbo for $3500. It looks and ran great. the same day I bought the car it spun a rod bearing. I tore down the motor and im replacing the rod bearings, main bearings, rings, gaskets, oil pump, water pump, and belts. The crank awas fine after a little polishing with some emery cloth. After I get it back together, what would some good modifications be to start off with? Currently the car is stock to my knowledge. I was thinking about first getting a front mount intercooler with 2.75 inlet and outlet to replace the stock intercooler. Then I was thinking about solid intake majbe from injen. s-afc II, injectors, boost controller, and for sure after market gauges because stock ones are crap.. can I get some help?
