Overbore
killab443
602
3
Nov 24, 2003
Howell, New Jersey
I just got a used rebuilt block and dont know of the overbor the guy didnt know. On the pistons slightly engraved it says .75 exactly how much over does that make the pistons. I know it cant be .75 over because that seems like too much./ There 2g pistons on 1g rods
.75 would be entirely too much. 0.075 might be a little more believeable.
i know this is an old post but to answer that the ".75mm" is the size of the piston. the ".30" is the bore of your motor. :thumb:
No.
.75mm=.030"
So the piston was marked as a .75mm overbore or .030" overbore.
The bore is actually 85mm, or 85.75mm in this case, which comes out to 3.3760" rounded to the nearest ten-thousandth.
the service spec is .040. Anything over that would be a junk engine just so u know from now on it isnt at all .075 over.
