over boost, boost source needed
SniperXr2
254
Mar 1, 2003
Arcadia, California
hey guy's. I just installed dejon tools ic pipes for a 14b on my 2g, now I am getting 15+ psi and the pipes are blowing off of my car. I think it is because the line coming off of the bcs now has noway to tell the boost running, i just capped it off, now i need a boost source. I was thinking the bottom nipple on my type s but now i got to thinking and I am not sure that is even a boost source.. I also thought about tapping into my bov line or a line in the TB. In short I need a boost source, thanks guys. Thanks alot.
-Rob
-Rob
Tap from your bov pressure source.
You're suppose to disable the bcs and remove the T on that line, just run the pressure source from the compressor housing/turbo outlet nipple directly to the mbc.
Also, a boost leak test is a must after any work done to the intake tract, you'll be surprised at what you find. ;)
He doesnt have a pressure source like the t-25 did. Get the pressure source from the bov line only as a temporary fix because the wastegate actuator designed to handle pressure and not vacuum. Dejon tool pipes for the 14b/16g/18g setup dont have any fittings on then so that means youll need to have one put in or buy an turbo outlet elbow that has a pressure source fitting on it.
