Dert
- 918
- 10
- Mar 8, 2008
Lethbridge,
AB, Canada
Allright heres the scoop, installed a turbonetics 57 trim a few weeks back with punishment o2 housing with tial 38mm mvs wastegate. Have the mbc turned right down and just running off gate pressure (17psi) and everything has been boosting nicely. So I jack my car up, change the oil and notice the rubber cap I put on the Intercooler pipe nipple (extra boost source) was split. I recapped it finished up with the oil change and ever since then i get 1psi of boost 2 if I'm lucky. I addressed the only small exhaust leak I had, have boost leak tested about 50 times and get nuthing but the one tiny leak at bov flange (that is fixed) I tried running straight from compressor nipple to the gate and get same result, 1psi of boost, I took the hose off completely (uncontrolled boost) and it jumps up to about 18 psi in a few seconds of getting on the gas. I have no clue as to why I'm not building boost, Ive searched forums for every boosted vehicle there is and cant find an answer. I'm guessing wastegate stuck open but I talked with punishment and they say no any help greatly appreciated as I'm at the point where I am going to just rip it all apart and start over wich I dont want to do because it took me a while just to get it to here
thanx-Gary
thanx-Gary
