kronus
- 652
- 27
- Jan 15, 2006
Independence,
Missouri
So I finally have the motor all back together, but I can't get the car to run right. After I got everything buttoned up, I test fired the motor and saw that I was running on 3 cylinders. All four had spark, but #3 was not getting fuel. Not a big deal, so I went ahead and threw the rest of the timing covers back on and bolted down all of the pulleys for PS, Alt, Water, yada yada.
Well, once everything was back together I got ready to diagnose the lack of fuel in #3, but I found out I was now only running on cylinders 1 and 2. Swapped injectors around, and the same thing happened regardless of which injectors were in the 3 and 4 spots. Obviously this is electrical. I picked up a working CAS to try, but nothing changed. I'm doubting it's the ECU, because I just barely bought this from Mindblowin_03 last summer before my swap. Mind you this was a freshly rebuilt ECU and it maybe has 4k miles on it.
Anyway, after doing some multimeter work, I've come up with these numbers:
-All 4 injectors have a resistance of ~ 2.3 ohms.
-All 4 injector plugs have 12 volts on the black wire side, but only 0.4 volts on the colored wire side. (I don't know why, and I don't know if that's good or bad.)
-Injector resistor pack has a resistance of ~ 6.x ohms across each of the 4 pins.
Also, when I pull the plugs and injectors, I'm getting spark on all four plugs (verified by laying them all on the valve cover and watched for arcing) and I'm each injector is clicking.
So now I'm stumped. I've double and tripled checked timing, and I just cannot figure out what the problem is. (BTW, I'm gonna check my compression tomorrow. Didn't get a chance to today just because I didn't have a comp. tester.)
Any ideas?
Any ideas?
