no spark on cyl 4 and 1, only 2 and three...
91_stealth17
Jun 13, 2010
Fergus Falls, Minnesota
ok so i've looked at all the other posts about this problem and most turn out to be the ptu but i've switched that out and still having the same problem. finally got my tsi running last week and have only driven it about 30 miles and it started to miss. Now it intermittently starts and when it does it misses unless the rpms are brought up. I also switched out my coil pack with another one and still have the same results. cylinders 3 and 2 have spark but cylinders 4 and 1 do not. any suggestions?
also this may or may not be related to the problem but if i crank it for more than just a few seconds the clock on my radio resets so it must cut the power to that as well? just trying to think of anything that may help.
The only thing I can suggest is the transistor pack. It should be on the intake somewhere. Don't get it confused with the resistor pack for the injectors which is on the firewall somewhere I believe. There's a way to ohm it out if I remember correctly. Search around on here for "location of transistor pack" or something of the sorts. that should help ya out a little I think
Thanks for the help! It turned out to be a bad CAS. I switched it out with a good one and now have spark on all four cylinders again.
