No Spark on cyl 1, 4
easa_13
Jul 10, 2009
el paso, Texas
Hello need help with my eclipse i don't have spark on cyl 1, 4 same coil, i did some testing : transistor unit OK i intercepted the ecu signal and connected it with a direct positite and i got spark on all coils transistor ok . Coil Pack, OK . Cam sensor signal OK . Crank sensor signal l OK. but the ecu is not sending a positive signal to the transistor for the cyl 1, 4 and for cyl 2 3 i have bliking positive signal form the ECU and nothig for the 1 4. could be My ECU??? or there is something else that can be bad
HELP i love y car but it does not start :ohdamn:
Thanks!!
It sounds like you're on the right track with the diagnosis. It sounds like the ecu to me.
