1G only my high beams work not low
awdtalon21
152
Mar 4, 2007
St. Charles, Illinois
i have 91 talon and only the brights are working, i have changed the realy and the fuse. i have put the headlights in another car so i know both the high and low work.
not sure where the switch is, but i grounded one the wires for the lights, now the lights work but something is draining the battery.
Defiant's right - Saw your other Post about Battery dying - You've got the Headlight relay hot all the time - I just deleted the HI - LO Switch in the column & mounted a Toggle Switch in the Steering Column Cover.
