only grinding in first! need help.
buhay6
1,661
65
Jul 9, 2010
Delisle, SK, Canada
Ok I'm just looking for some knowledge on what my problem might be before I track down a new tran. Little info my cars a 92 awd I got as a roller 2 years ago found a guy selling a 93 awd this last august complete running car with a blown clutch or tran so I bought it and found a disintegrated clutch everything jived with his story. So I swapped everything into my shell (other one was toast) did a bsek on the engine found I forgot the linkage mount for the tran in the parts car which went to scrap. So I went and got a 90 linkage setup and adjusted it so I had all my gears but first would alway grind and bounce out unless I let off the clutch and then tried again it would work good no grind. So I drove it around town a couple times to make sure I only had minor electrical gremlins.....then it lost all gears. Limped it home in 2nd and found the clips holding the tran cables to the bracket all popped off. Fixed that and now have no first period it just grinds like a mofo and pops out and my cables have no adjustment left.
Anyone had this happen before to them? What was the problem?
