Street Build Oner's 1992 Galant VR-4 RS Tribute
My current USDM GVR4 -> JDM RS Tribute build
Oner
7
Feb 8, 2022
Fort Myers, Florida
Upgrades
Evo III Big 16g MHI TD05H (Forced Performance)
Evo III Ported & HeatCoat Treated Manifold (Forced Performance)
Evo III o2 Housing
ETS Galant VR4 FMIC Kit
K&N Filter & Custom Intake
APEXi 2.5" Exhaust
2.5" Downpipe
STM Atmospheric o2 Housing Dump Pipe (modified to fit VR-4)
PTP T3 Turbo Blanket (Black)
TPP FP Manifold Blanket (Black)
DEI 2" Pipe Wrap for Downpipe to Race Catalytic (Black)
Fluidampr
HKS 272 Cams
TODA Cam Gears
Zaklee Clear Cam Gear Cover
FIC 880cc Fuel Injectors
255lph Supra Fuel Pump
Braided SS Turbo Oil Feed Line (Forced Performance)
Hallman style manual boost controller
Mishimoto Carbon Fiber Catch Can
GPI Silicone Cooling System Hose Kit
Vibrant Hoses & A/N fittings
STM Valve Cover A/N Fittings x2
Aeromotive Y-Block (dual -6 to single -8 to catch can breather)
Upgraded Valve Cover Half-moon
NGK BR7ES Spark Plugs
20mm Front Sway Bar
26mm Rear Sway Bar
Whiteline Front Strut Tower Brace
Whiteline Rear Strut Tower Brace
JIC Magic FLT-A2 Coilovers
Custom Subframe Connectors
JDM GVR4 RS/Evo I-III Close Ratio Transmission w/ USDM Final Drive (Built by Tim Zimmer of TMZ Performance ~ Stage 2+)
Southbend TMZ Performance SS-X Series 2700# Pressure Plate w/ Full Face Segmented Friction Ceramic Clutch Disk
Competition Clutch Street Chromoly Lightened Steel Flywheel
Competition Clutch Forged Steel Clutch Fork w/OEM Throwout Bearing
Extended Slave Cylinder Rod
Redline Fluids for Trans, T-Case & Rear
3 Bolt LSD Rear (USDM)
4WS Delete
Shifter Assembly Solid Chassis Mount Kit
Torque Solution Shifter Base Solid Bushing Kit
Torque Solution Transmission Cable Linkage Solid Bushing Kit
Shifter Pivot Bushings (OEM)
2g MAF Mass Air Sensor
Keydiver Chip
A'PEXi SAFC II
Exterior
JDM RS Front Bumper w/ Dual Projector Driving & Fog Lights
JDM RS Rear Bumper
JDM RS Hood w/ Vents
JDM Headlights w/ HID's
JDM Clear Corner Lights
JDM Power Folding Mirrors
JDM Keyless Gas Door
JDM Visors
JDM Rear Glass w/ Wiper
JDM Rear Glass Valance/Rain Guard
JDM Window Rain Guards
JDM OEM 4WS 2.0i DOHC 16V Rear Door Markings
JDM Mitsubishi Motor Corp "MMC" Trunk Badge
JDM Galant VR4 Style Trunk Badge
JDM Tail Lights (w/"VR4" delete)
JDM Eterna Grille
JDM Full-time 4WD Grille Badge
JDM Front Plate Kit
JDM Galant AMG Type I/II Spark Plug Valve Cover
BBS LM F1 Championship Edition Wheels (w/ Red Center Caps)
Continental Extreme Contact Sport Tires 225/45 ZR17
McGard SplineDrive Lug Nuts & Locks
Interior
RECARO Evo 9 Front (SSL) & Rear Leather Seats
'89 Underdash Kit
Mofugas 2 Gauge "A" Pillar Pod
Mofugas 3 Gauge Radio Panel
Autometer ProComp Ultra Light Gauges (Boost, AFR, EGT, Oil & Water)
Custom Audio System (Interior Speakers, Wiring, Single Din Radio, Amp & Sub
Working Cruise Control
Working A/C
  • Wanted 6 bolt NT water pipe
    • chrisman287
