one way vacuum valves?
mechanix565
165
Apr 19, 2009
Pawtucket, Rhode Island
should i have one way valves on all my little vacuum lines? BOV line, Wastegate Line, Fuel Pressure Regulator Line, Brake Booster Line etc? or just straight lines from manifold vacuum to the components?
The only place that you might consider a check valve would be in the PVC or breather lines. So that you will not pressurizes the crankcase. Everything else should have an unobstructed line. Oh and the brake booster already has one in it.
