one of the screws broke inside of the turbo
ZFRED10
73
Nov 11, 2008
Boiling Springs, Pennsylvania
So when i was driving down the road the other day, the bolts from my j-pipe to my turbo came loose so i got some new screws because the old ones were not long enough. I put the new ones in and they were fine. Today I was changing a coupler on my intake and I had to take off the J-pipe. When I put it back on, I guess one of the screws broke inside of the turbo threading where it bolts up to. I don't know what to do now. My car is running like shit because of the gap in the j-pipe and I don't want to drive my car until it it fixed. What should I do?
Will I need to remove my turbo to do this and what if I stripped the threads. Don't know if I did or not.
Before you extract the broken bolt shank, stuff a rag into the compressor
inlet. That way your won't get chips down in the compressor.:thumb:
Just get the bolt shank out. Then you can assess the threads. If they are
stripped you might be able to fix them with a tap. Otherwise install a helicoil
(can buy kit at local auto parts store).
Good luck
