? on paint needs
I can paint a 1g with less than 2 qts. of color. because 1 qt or color reduces most times to 2 qts sprayable. so if you go buy 2 qts. of PPG it reduces 1:1 so you get 1gal sprayable...primer/sealer will be dependant on the car. It would intel how much body work is needed, but clear you can expect to use about 3 qts if it mixes 4:1.
i painted my whole 1g House of Kolor kandy green for everything it was about 350 give or take
I have to agree with Evil X, I used about 2 quarts (unmixed) to spray the outside of a my car, that was glasurit 2:1. and 3 quarts of clear unmixed at 2:1:10%. The actual amount of straight base you will need will more than likely depend on your mixing ratio. The higher the first number the less paint you will have when it is catalyzed. Spraying a 1g with the two tone would probably only require about a quart and a half of straight base.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
