- Thread starter
- #26
imdrax
- 172
- 1
- Aug 7, 2003
napa,
California
alright well then i am grounding off the right clip then. i do notice my rpms slightly change but what i dont understand is that when i have it grounded or not grounded i see the ssame reading with my light.also while im looking at the mark to set my timing my mark fluctuates significantly it will jump +/- 2* or so. i will pick up a new coolant temp sensor tommorow for sure . i didnt realize it was so significant to my timing advance.thank both of you guys for your helpful input. i willpost back after i make a few changes to let you guys know how its going.Originally posted by kpt4321
The ground strap isn't going to make a difference.
Get a workin coolant temp sensor on the car, it's never going to run even close to correctly with that dead one on the car. Fix that problem.
To adjust timing, there is a plug behind the battery in the harness. If you pull the cap off, there is a plastic prong and a smaller metal prong inside.
That VFAQ picture does show it, it's just hard to see.
The logger shows you the total timing advance, ASSUMING 5 DEGREES OF BASE TIMING. The ECU just assumes that the CAS is set correctly, because it has no way to know if it is not. Therefore, if you have the base timing set at 6 (for example), then you need to add one to all the readings on the logger.
When you change the timing, it will not change on the logger. Additionally, in order for you to properly make base timing changes, you need to unplug the logger.
