TimF
- 821
- 7
- Mar 14, 2011
Aurora,
Illinois
I have heared many times by many people to NOT change trans fluid after a certain amount of time cause it may wreck the trans. Is this true, im wraping up maintance and fluid changes but the trans fluid has not in almost 10 years (previous owner was my mom BF so i know what he did/ did not do) Should I be fine dumping all the fluid and refilling it, or should I do what I read somewere else and Drain a quart add a quart till it is all new again. I was also thinking of adding seafoam in there to, has anyone ever done that or used any other auto trans additves. Oh yea my trans is auto bty.
Did these people that told you not to change your trans fluid also inform you to change your boost fluid,
change your fluid for the love of god and no sea foam. If your worried about getting it clean ruin some cheap fluid for about 20 mi then drain it and put in the good stuff.
