Clutch fluid..??
UVaJester
219
Jun 14, 2003
Virginia Beach, Virginia
I am getting ready to bleed my clutch and replace all the fluid. I was wondering what fluid do I use... is there a better brand than another..?? Thanks in advance.
Jester
You use brake fluid for the clutch master cylinder. I put Valvoline SynPower DOT4 in mine. But it's really not going to make a bunch of difference with any kind you would use, unless you were to buy some completely generic store brand.
Even completely generic is fine for the clutch. DOT 4 or DOT 3 either one. The clutch isn't crucial like brakes, nor does the system deal with as much pressure and heat.
Thanks for the responses. I am getting ready to do the samething for the brake fluid. Is there a better brand brake fluid than others..?? Thanks again.
Jester
Hi i need ur help and i'm not sure i've look in these site pretty much but can't find it. my question is i have a problem with the clutch i've push the clutch all the way in to get in gear but over the month it start to get hard to pust the gear in so i've adjust the push rod on the bottom of the clutch all the way out now and it work fine.but now it getting to the same thing and getting worst to the point that i can't even adjust it anymore.can u please help meeh ? Thank you!
