Oil+turbo=help
99VR4
Aug 5, 2013
columbus, Georgia
I know i dont have a ''dsm'' i have a 99 3000gtvr4 but i know you all know 16g more then my 3000gt fourm's so i hope you all can h
About a month ago i sent my 16gs sentoff to get built to the max,
now i sent them off bc thy did the same thing but it took it about a day after i just put them on before starting to leak...
i got them two days ago, put them on yesterday and i drove the car for "no bullshit" 15sec and oil is coming out of everwhere the charg/ex sides and i can see oil coming from the wheel.
now my oil presser is around 80psi at idle.
do i need a oil resticter?
ps. i did check the return line for blockegs and bents but thy are good?
any clue?
16G's want no more than 48psi of oil pressure at the inlet, period- your idle pressure is off the charts...although if you're seeing that much oil after 15 seconds of low-RPM drive time, you likely have a pretty serious drainage problem as well.
I got up to 12psi of boost thats all ,then i turned around and say the oil, but i am going to get a restricter todat and put it on, i hope it will fix it
