Oil pressure head mod
inthemidst
363
24
Aug 25, 2009
PALMDALE, California
I have a 2g 4g63 head and am tired of seeing my cams getting scratched. I already did the head bolt hole mod. Anyways just want to get a second opinion on blocking off the two oil bleed holes in the head.Any thoughts .Pros and cons.Thanks.
5-6k miles since rebuild.[DOUBLEPOST=1417991277][/DOUBLEPOST]I was thinking the high oil pressure might cause the lifters to become solid which will bend the valves
So do you think the extra oil pressure might lock up the lifters causing my valves to bend.
I'm about to block off the two oil relief holes that are in the head.Which should increase my oil pressure substantially
What I want to know is if I increase my oil pressure in the head.Will it seize my lifters causing my valves to bend.
What you want to know has already been made clear, but you insist on a band aid fix.
Go to the root of the problem, which could be any of the ones previously stated, go to the source, if not you will have bigger problems later.
I dont see anyone answering his questions clearly at all...
Well I did my research and found that I can't plug them.Theyre regulating the oil pressure to lifters.What a waste of oil volume.
Sure they did. See the quote at the bottom. Get a real gauge to see what the pressure really is, then start at the oil source (pickup and oil pump) to start.
I'd say go get a real oil pressure gauge and find out exactly how much it has, and if it's low you need to check the pickup tube, if that's all good and the gasket on it is good your oil pump probably has an issue.
