Oil pressure on head?
4g63telantra
454
Dec 10, 2004
Toronto,
k on the oil feed line on the head, can i place a oil pressure sensor or a oil temp sensor? (will it be the same pressure/temp on the head and the oil hosuing?
I have thought of this also. There are a few oil plugs right around the banjo bolt that you could pull and hookup a pressure sending unit to I am sure. As for pressure and temp being the same, no ....less pressure for sure and lower temps I am sure.
k well if i wanted to run a oil feed from the oil hosuing (90) would i have to remove the temp/pre sensor? if so which one should i remove?
I am not sure but you might have a couple of spare outlets on the filter housing with plugs in them right now. I had one which I used to insert my temp probe, I then removed my stock pressure sending unit to insert my Greddy pressure sending unit. Just have a look and see but I think you should have a plug or two on there to remove.
