Oil Pressure Falls Under Boost
TurboChrged93
124
Jan 5, 2005
No where Fun, Pennsylvania
As my RPMs rise but under vacuum *no boost*, so does my oil pressure. Normal.
As my RPMs rise *with boost*, my oil pressure slightly falls. Abnormal.
Diagnosis?
This is all going from the stock gauge in the center, it never goes past straight up unless it's a cold start. :dsm: :cry: :dsm:
So you think it's nothing wrong with the condition of my motor... you believe it's a bad connection?
I would get a real gauge on there, even if it's just a mechanical cheapie that you run under your wiper for a few runs. The first step is positively confirming there's a problem :thumb:
Well, that's the first, best hope. And a fairly likely suspect on DSMs with their connectors out there in the breeze getting slapped around by the wind. But it is dicey to make diagnosis without touching stuff.
