oil pressure extremely high
Kod
289
Mar 29, 2011
Kingston, Pennsylvania
When I bought this car my friend never had high oil pressure. Transmission went and car sat 2 - 3 years. When my car is fresh started oil pressure is at 100+ psi and my gauge maxs at 100 which the needle is always pinned. Takes 5 - 10 minutes before pressure drops to 20 psi. The balance shafts have been removed since my friend drove it before the transmission went. Anything I should look into before the long process of porting out the relief valve?
5-30 royal purple but have used casttol and mobile 1 with basically same issue in pressure as for rpms idk until I talk to my friend his driving my car until im back from vacation.
Temp is 20 - 30 in the morning and 50+ in afternoon.
What is BSE? also, it is not just in cold starts. It is all year round.
My friend eliminated the balance shafts before installing the engine. He doesn't recall the oil pressure ever being high but I haven't had the chance to talk to him today anyways I do know even after engine is hot if I floor it my pressure does max out on my aftermarket gauge. Which this issue is starting to causes gaskets and seals to start leaking.
So guess my best bet is following the guide on porting the relief valve out and see if it stops then start replacing bad seals.
You need to port the valve in the ofh and by the sounds of how extreme your situation is you might need to cut a coil from the pressure relief valve.
What he said. And check for build up cause you said it wasnt moving for a while chance are you got some build up going on causing less flow
At least 11psi at idle. about 30psi at 2k and keep rising from there. Around 70psi the pressure release valve should open and it shouldn't get higher than 75-80psi. If higher then you need to port and if necessary cut the spring.
