Extremely high fuel pressure HELP!!!!
gtbread77
131
Jul 17, 2010
windsor, Colorado
I have a rewired stock fuel pump with a aftermarket ebay afpr also a venom fuel rail. my gauge on the afpr was pegging out @80 psi so it could be above that i can hear the fuel pump screaming in the back of carOMG, even with the adjustment all the way out. i took the afpr apart and checked and cleaned it out everyting looked normal, no torn gaskets and spring looks fine. will i had it apart i blew into the return line and i could blow air into the tank it took alot of my air force but i do have a full tank so i don't think it's plugged. so my question to you guy's what could it be this is my dd so i gotta have it!!!!!
i just changed fuel filter a month ago so i don't think it's bad. could my fuel pump just be going bad :banghead:
well the operator error is probably the most likely. LOL. umm well the return line i can blow into the tank so it's not that. k so i guess the afpr then keep you posted maybe somebody else will have this problem
So, you got a cheap FPR and ricey fuel rail with a completely stock system otherwise, and you're wondering what's going wrong?
Install the OEM fuel rail with the OEM FPR. Problems solved.
