Oil pan removal
Napster
96
Jul 18, 2007
Pocahontas, Arkansas
I'm trying to get my oil pan off right now and I can get it off due to it hangin on the rear main cap, I have all the pan bolts of and its hanging down, I have tried to pull this sucker out every which way, are there any secrets or what?
its not hangin on the rear main it is hanging on the oil pup pick up tube....its hitting the windage tray part of the pan...hope this helps guy
What the above posters said, it's hanging on the pick-up. Lift the oil pan back towards the block and slide it towards the back of the car, guide it that way around the pick-up
As other have said...Its not rocket science...Its getting hung up on something.
Also 2 of the pan bolts are SHORTER than the rest. Make a note of these for re-installation. They go on the timing site of the pan. If you forget, the center bolt will rub the belt!
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
