gsx-box
- 46
- 1
- Jan 13, 2006
Albany,
New York
I have Oil loss of about a quart per hundred and buildup around oil filter. Where is the leak?
It never leaves drips when parked or idling and does not burn oil as the plugs are perfect after 40K miles. However, the oil filter area and the AC compressor is covered with grime/fresh oil.
I am lazy and do not want to do the oil pump. Is there anything else in that lower area that could be resealed other than the oil pump below the timing belt?
center bolt and oil pressure sensor were loose.
