oil leak. WHERE?
bowens1414
123
Oct 30, 2012
Bradenton, Florida
ok so i just put in the new slave cylinder drove the car pretty good i get home to just check things out and i had smoke white smoke coming from under the manifold on the left side of it. from my quick checking it doesnt appear oil is coming from the turbo but potentially from a line under it i also recently replace the oil feed line so i know its not that. just curious because this car has given me hell lately. im just out to see if anyones had this problem or know if its common ahh im just frustrated any help is nice.
Check your hoses to see if theres any pin holes or there could be a small crack in one of your hoses. I had that problem a while back on my GSX and it was a cracked line. Couldn't see where it was comming from but i found it leaking and discovered the problem when i took off the hoses.
I recently had a oil leak in one of my steel braided oil cooler lines. Was very difficult to find because the leak was from the inside.
