Oil Leak, No Start... with New Gasket & Valve Cover!
bluelaser92
176
Oct 13, 2002
Steubenville, Ohio
I just replaced my valve cover on my 1.8L (cracked the old one).
Problems:
Leaking oil around the new gasket
Car turns over but doesn't start
I cleaned off all the old gasket & cleaned the replacement VC with WD-40 and steel wool, then soaked it in hot soapy water. After it dried, I inserted the new gasket and installed it. I tightened the bolts with my fingers, and then gave them an extra 1/4 turn. After trying to start the car and noticing the leak, I kept turning each bolt 1/4 turn, but it still leaked. I was afraid I would crack the new VC, so I stopped.
Before the VC cracked, the car sat for about 2 months (ECU repair), but then started right up. That's when I noticed smoke coming from the VC. I shut the car off and saw leaking oil, so I tightened down the VC and it cracked. Then the car sat for another 2-3 months while I tracked down a 1.8L VC. Finally the other day the part came in, and I installed everything like I said above, except now the car won't start.
I realize having the car sit like that isn't good... I'm just frustrated right now, going without my car for 5 months straight. Somebody please help me out...
Well, i'm not sure about the oil leak, but as for the car not starting...this is after an ECU swap? or repair im not sure...If it was repaired, are you sure it was done correctly? If it was swapped, are you sure you got the right one? Simple questions, but not starting after an ECU issue is usually that...
The ECU was repaired, and yes the car did start after that. The repair was done correctly and very well, and the car fired right up after the ECU was reinstalled... It's only now, after installing the gasket and valve cover, that it refuses to start - even with starter fluid.
Please help me out here, guys... I'm stuck. :(
Just finished replacing my battery. The old one was pretty bad, didn't keep a charge. Car still won't start, but seems to fire every once in a while now... I think the battery may have been part of the problem. I also bought some gasket sealer, so I guess I'll take the VC off and redo the gasket with sealant...
If you've got any other ideas please post'em... I'm still stuck. :|
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
