gusu
- 1,950
- 33
- Sep 9, 2009
Independence,
Oregon
Okay, so last time I changed my oil my I put on the filter and it tightened down and it spun and spun and spun. Took it off put it back on and tightened it down again. It seemed to be perfectly fine and tightened down but stopped spinning.
So I start up the car thinking it's tight and back the car out of the garage (about 3 feet) and then realize the oil is EVERYWHERE. Luckily I have about 2 quarts left. I then get under the car and start tightening the filter on and it was fine. So I tightened it down with the filter wrench til it eventually stopped spinning. After I tried turning it a couple more times I filled it back up with oil and had someone crank the motor while I checked for leaks. It didn't do anything, so I put it in gear and drove it down the driveway. It was perfectly fine for the entire time I had the oil in the car.
Now for what just happened. I put the filter on and tightened it by hand until I couldn't turn it anymore. After that I turned it with the filter wrench a couple times to make sure it was tight (but didn't want to over tighten it so I didn't do anymore) , knowing what happened last time I put my car in reverse started it and let it move back really quick to see if it was leaking, sure enough it was so I turned it off before the oil could drain out very much. Remembering how it was free spinning last time I decided to take it off and tighten it back up.
This time I decided to tighten it until I couldn't get it to move freely with the wrench at all. I cranked and cranked about 8 rotations AFTER I had turned it by hand til I could no longer get enough grip to turn it anymore. It's STILL not tight however the filter is tight with the housing!
I know the bolt the filter screws onto comes off with a 24mm deep socket. My question is what exactly does that banjo bolt screw into? My thoughts is since the last couple times my filters have been a bi*** to get off even with a filter wrench that maybe some how it came loose from having to apply too much torque.
Do you guys think I should torque it back down and see if it just came loose or do you guys think I should take the OFH totally off the car and see what's going on? I personally don't want to go out and spend another 20 bucks on oil.
