OIL FEED LINE RELOCATION KIT bolt stuck?
tsiawd1996
54
Oct 20, 2006
kingsland, Georgia
i just got my relocation kit today last part for my car to run. well i tried to take the allen key bolt out it will not come out! it is starting to strip it out? what do i do? is there some type of lock tight on there? need help asap
Ok. its probably just old and stuck in there. Soak it down with pb blaster for a while and if that doesen't work you can weld a bold onto it wo spin it out. Or jbweld one on.
Worst comes to worse you can drill it and use an eazy out
you think that will work i used some lube on it going to try the bolt thing now thanks i hope that works
    • george bromwell
    • pma1123
    • Sdcryan1
