oil feed line adapter size help :(
KaLo_o
227
Mar 9, 2009
Quebec, QC, Canada
1g dsm turbo...
so ive ordered a set or braided lines for my turbo...14b, and there is everything i need except for one thing....the dam oil feed line dosent have the right adapter for me to mount it on the block. i have a male to male adapter that fits on one side...but the other side is too big!!
im about to order a few things online, and before i order everything ...i want to include the adapter i need...
can anybody tell me the correct size male to male adapter i need to mount on the oil feed line i have?
thank you...
PS: dont post anything saying.... " just block it off and mount it to the oil filter housing "
i am aware of that and im not going that way. i will be mounting an oil cooler there soon!
You mean you're trying to connect the -4AN line to the head and they didn't give you a banjo fitting?
Honestly I don't see the benefit of going to a braided oil supply line when feeding a TD05H turbo from the head. Hell a new 1G oil supply line is only $23....it prevents all the hacking necessary to make the braided line fit, and it also has the proper restriction built into the banjo fitting at the turbo- something you won't get with a braided stainless supply line.
