oil drain line
Have you already assembled the hose and fittings and found it won't screw on?
I have a similar drain line and when assembled with the stainless hose and fittings, there was not enough flex in the short amount of hose between fittings for it to screw on. Ended up using push on type AN fitting with just plain hose, which has much more flex, and it worked no problem.
