Off-Roading Armor
The rally cross car I have ended up with has a aluminum road sign as the front bash plate for the underside starting at the lower front of welded in transverse support (Round looking pipe) and Service panel channel added between that and in front of radiator mount. Front vertical bracing still needs tying in.
bracket. I will take picture of it, if I have it here in shop.
Nothing Fancy, BUT Works!
Most likely will try to adapt a quick removal retaining system, HOPEFULLY Possibly tool free, depending on security of retention system used.
E.G. = it doesn't fall off while being thrashed about on uneven pavement when in use!
Presently bolted on with numerous fasteners.
Secure, but would take too much time to remove for a inspection or repair during pit stop for actual Rally timed multiple lap event.
OK for something like a one lap autocross type run.
