ONe off adjustable cam gear... :D
turboglenn
6,375
123
Nov 5, 2007
RIpley, West Virginia
well, My fidanza exhaust gear is cracking in a couple places so a while back i set out to makea few center hub foirit.. here's it is 3-4 momths later (welded the toher one) and i fonally got motivated to finish it
I was gonna make a new aluminum piece inside the fisanza outter ring but i had some stock gears laying arounf an figured what the hell..
TOngiht i put the cam dowel hole in, slotted the adjustment grooves and turned a lip on it so that when i cut the 5 "webbings" off the OEM cam gear to fit the center I can put one of a kind set of customcamgears on my mitsu
They re made from 6061 -t6 alumium and the OEM gears are steal (ony hve one made as only one was letting loose0
I't sNOT perfect,and although smoothjyou cansee surfacing bit marke on itin the light..
I figured not bad for a broke asswith time and materials
I havetopshortenth 5 legson the outter gear in order to get it to backspace correctly but i'm almost there, jsut in more paing thani can work in tongith...timeto readon here
oops got same pics twice, here's the front
Well, after a short break and dinner i finished it :D
Here's it one on a head next to an OEM gear from the front and also a view from the top showing how they perfectly line up :D (i'mproud of yself on this one)
There's also a finished view of the front of the gear with the disk sunk in a cut OEM outter gear ring and a view fromthe back showing what's left of the webbing and how it's supported (there's a little cean up of the slots left but that's no bid deal, it's late and i wanted to relax)
Here's pics
All i need to do is drill and tap the steel pieces of the outer gear that go behind te "slots" for some m6 orm5 bolts and then put it on a dividing head and mill th degree increments into it (as well as make new "timing marks" that are perfectly aligned when the adjustment is centered )
wher the "finger" reach into the inner disk that's where i need to clean up the edges of those recessed areas, but like i said i'll do that tomorrow.. this thing won't go on untill i either feel like changing the cams (be nice to get a 272 intake one) or if i have to replace the waterpump or something... or if the cracked fidanza this was made to replace gets any worse *fingers crossed*
EDIT: #2 Couldn't resist finishing it off with a little drill and tap work.. found some m6 x 1.0 allens nd somenice looking bronze washers to finish it off :D
    • Sdcryan1
