oem vs aftermarket high 2gb spoiler
I would suggest not putting that on your talon unless you do a 2GB conversion. They just dont look good on a talon with stock bumpers.
It doesn't list what material it is made out of, which makes comparison kind of difficult. But i would assume as long as it is a quality fiberglass or polyurethane, you wouldn't be able to tell a difference. If your curious about the actual shape, i'd be willing to bet they took a mold of an original, so shape wise they should be identical. Thats not to say the final product will be top notch. It might have bubbles, pits, dimples, cracks, etc. depending on the quality of each replica.
I haven't seen an OEM one in person yet but the one I have is off of ebay. Got it about 3 years ago and its still doing fine. I'm not sure how it bolts up compared to the stocker. The one I got came with these little thingys that threaded into the mounting holes and had a point to them. Then I laid it on the hatch and pressed down and it dimpled the paint where I needed to drill. It attached with machine screws that threaded into metal inserts in the fiberglass spoilers. You can see pics of it in my profile compared to those that have an stocker.
    • Sdcryan1
