OEM Ignition Coil alternative
SoonerTalon
73
Aug 11, 2013
Moore, Oklahoma
I have a 1991 Eagle Talon TSI and my ignition coil are not transferring current any longer. It appears that this setup has dual 2 plug coils which are priced at at $140.00 and I will need two which is rather pricey.
Are there any higher performing coils that will work with 1G's?
Two coils im confused I have only one coil pack, never heard of an alternative, a coil on pack is more than that. Coil packs are less than 75 bucks used .
The stock coil packs are proven to handle over 700whp fine, you can source a used one in good condition pretty reasonably in the classified section on here.
Look closer, there are two separate, identical coils on the bracket (unless you have a '90).
No, the cable to the coil is showing hot but when I plug a spark plug into one of the wires I am not getting any spark. Could the transistor cause this?
