oem bse kit help......asap
Do NOT use that kit. The stubby shaft does not have the oil grove in it. Go to one of the vendor sites and get one from them. Street Tunned Motorsports or Extremepsi would be two close ones for you.
You NEED that grove in the stubby shaft. I know for a fact that the STM one is an OEM stubby shaft.
STM - DSM ENGINE COMPONENTS | PISTONS | RODS | CAMS | TIMING | OIL COOLERS | GASKETS (scroll down)
EDIT:
Extremepsi also has an OEM kit, but is more expensive.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Balance Shaft Eliminator Kit : Mitsubishi Eclipse 90-99
