Odd electrical prob
eightmn
Dec 27, 2004
Towson, Maryland
A few weeks ago I was driving on the highway and when I hit the brakes to slow down I get a click and the antilock and check engine lights come on happened one more time before I went and got the caps replaced on the ecu. Everything fine until yesterday when I park it and it just wont start like the battery is dead. Get a jump and it idles, step on the brakes and it cuts and get the click from the console, try to drive it and it happens again and again, pull over pop the hood check all the fuses and fusible links wiggle them and press them in and everything seems to be fine. This sound familiar to anyone? let me know your ideas, any help will be greatly appreciated
Simply what could cause the ecu to reset and the car to cut off for a split second. Had the caps replaced in the ecu and they weer not leaking. Alternator is pushing 14 volts what else could I check?
Just pulled the error codes and there are none
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
