Slippi84
- 4,454
- 20
- Jun 8, 2005
Cinnaminson,
New Jersey
Isn't that 2nd manifold's flange upside down for a 420a? And what a spot to put the external wastegate flange, it's pointing directly towards the radiator and fans.
Even if you did "modify" that turbo mani to be able to bolt up to the head, those pipes are still sitting extremely close to the radiator hose (as in probably touching). I doubt it would last long with it like that.
It's not upside down it's called a top mount manifold. Check out most guys running 42r's that's the kinda of manifold they have. As for the radiator and the external position I would never run a open dump that is asking for crazy underhood temps you get a dump tube that points down pas the fans. It doesn't stick out as far as it looks in that picture though the size specs are on their site. The modifying I was talking about dealt with the ram style not this style too.
, that would be stupid. I guess the real question would then be: "how much of the t-stat would need to be removed according to which run of manifolds you got, because clearances would not be the same for every piece. Either way its rediculous and I know you stated you wouldn't do it anyway. I was just confused and wanted an explination.
