OBD2 Doenst Connect
What do you mean by obd2, you have to be specific. You mean the dlc? (data link connector) or the scan tool?
^^ Yes my dlc. I have tried to plug it in to read my codes and it doesnt. I have tried it several times, and with different readers so i think that my connection is somehow bad however.
Someone mentioned looking at a power wire? But i have no clue which one it would be.
Pin 16 is your power supply, found a diagram from talk. Check the back of the interior driver side fuse box for corrosion, I had this problem when I first picked up my dsm.
Pin 16 power supply, pin 5 ground, and pin 7 to the ecu.
+1 on the rusted/corroded fusebox. Once that was replaced, it worked everytime.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
