o2 Sensor help!!
96talontso
300
Jul 12, 2011
Edmonds, Washington
I'm installing my downpipe and cat-back and the o2 sensor i believe it is that screws into the pipe after the cat is COMPLETELY rusted on and i have cranked and cranked on it and it will not come off without me completely stripping it. I'm not sure what to do so please help!
Have you tried using a cheater bar on the end of your wrench?
Have you used pb blaster to try and loosing up some of the rust?
Also there is a socket made specifically for removing o2 sensors you can rent them at your local parts store.
Breaker bar and penetrating oil will work wonders. Torching the bung will also loosen it up too by expanding it out away from the sensor.
