O2 Sensor - Need Help ASAP!
98KreeClipse
Jun 29, 2003
Muncie, Indiana
Okay, so I got the O2 sensor itself disconnected and pulled out, but now I'm havin' some serious issues with the other connection at the other end. I realize that I'm supposed to push in a button/tab and be able to pull it straight out, but when I go to pull it out it appears to be gettin' caught on some kind of metal hook or bracket. If anyone has any ideas of what is goin' on, I'd be more than glad to hear them. I'm out of ideas! :( Thanks!
i assume you're talking about the front o2 sensor.
there is a clip that it sticks to the engine with. push the whole plastic joint back toward the battery and it will slip off allowing you to disconnect it.
there is a tab to push down on the sensor side of the connector.
AIM me if you have more questions, i'm gettin off the forums to do homework soon.
This connector had be baffeld for a few minutes as well. You have to pull on the piece with the plastic push clip. (the side facing the firewall).
The remaining connector has a pice of metal bracket inside it. Bend it around till teh connector slides out.
Ahhhhhhhhhh sweet relief! Finally got the damn thing popped off of that metal clip and everything is complete! I appreciate the help guys! :thumb:
