O2 sensor simulator wiring help
BoBbOrAzE
301
6
Apr 29, 2004
Chicago, Illinois
Hi, I am currently trying to eleminate my rear o2 cel by means of following the wiring diagram posted on vfaq and I was curious if anyone with any experience could help me out. I am stuck on the part where it says I need ~12 ohm, 12 watt minimum resistor to connect between the two heater elements of the o2 sensor. My local radio shack only carries resistors up to 1/2 watt. I know the blue is the o2 signal and the white is the ground so i figured maybe there was something else I could do with the blacks. My next step is to order a higher wattage resistor through the internet but I figured I might as well check to see if anyone else has any suggestions maybe I misunderstood something?
EDIT: For anyone reading this years later, I ended up making it myself and as well writing an article. Tech article for it is here
Thanks! I also found many more threads using the word "bypass" instead. I will see tomorrow if my radio shack has them in stock.
a_scobel:
Your pic doesnt work.
EDIT:
What the fu(k!
Why are people bringing back threads from so long ago????
Was it really worth it to bring this thread back just to say "they dont sell simulators on that site..."
