o2 not cycling (log inside)
dynedta
33
May 10, 2010
Massillon, Ohio
heres my log, o2 isnt cycling (brand new) also it seems like everything is really rough, any ideas???
agggh I should add im using 3"gm maf with ecm cable blow through, evo 560s, 43psi base fp
Cant look at it right now as im at work but you can get a bad o2 sensor even if you just purchased it so get a multimeter and get testing it.
Something strange is definitely going on.
It looks like your O2 signal is intermittent (maybe a wiring issue?). Pull another log and include your battery voltage, ICS, and idle switch.
Have you adjusted your TPS? Your idle seems to be high and not very stable as well.
Global fuel is close at -25, but you have deadtime set to 0. I have no idea what the DT for Evo 560's should be, but I'm pretty sure it isn't 0. :)
With the GM MAF in blow-through, you almost certainly have airflow issues at idle, but you haven't done any compensation for it yet.
EDIT: In that log, you have the ECU locked in BISS adjustment mode.
ok heading out in a second to do another log with revisons, i have done the tps adjustment (via dsmlink vid), yea global settings should 18% like artic said with dt set at 0, hopefully after i get this o2 thing figured out it will help the maf situation
Where are you getting 18% for fuel?
Using the calculator in link, I come up with -25.5% for global if you are running 43 psi base fuel pressure (although I'm not sure why you aren't at 37psi). And why would deadtime be 0? Although it's possible to have DT at 0 (depending on what the battery voltage DT points are), I would think something between 200 and 400 would be a more likely starting point for an injector of that size.
EDIT: Just saw that the ECMLink page recommends a deadtime of 0...not sure if I would trust that value though.
I got the car with it deleted, it has a blockoff plate on the bottom of the tb, I asked why it was done and was told because the car was to be a spring/summer weekend warrior of sorts. I thought the o2 should be cycling during idle in closed loop? It seems to only cycle when the car is held @ a rpm. Any suggestions on where to start with the idle tuning? It came with the stock injectors, 2g maf and safc (all have been removed)
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
