O2 housing: different bolt patterns for garrett and mitsu turbine housings?
definitiveno
1,237
8
Sep 8, 2004
Reno/Sacramento, California
In otherwords will any of the mitsu type o2 housings (evo III, ported 2 gen) fit my garrett turbo? If not wich ones will?
What kind of Garrett turbine housing is it? Some are made for band clamp mounting and others have a bolt plate setup. Reguardless most will not work with the mitsu O2 housing unless its a mutt/hybreed turbo.
Just like Nanan said. NO. Unless you are talking about a garrett turbo with a mitsu "style" housing...(aka a bolt on housing) which would make the turbo a hybrid. If you are talking about a garrett hybrid, then a 1G, 2G, EVO3 housing will work. I have a bulleye turbine housing and the holes dont quite line up when using my 2g o2 housing....buts thats another story.
The turbo is full garrett, no hybrid. It's full garrett, 4 bolt, internal gate.
I have a bullseye turbine housing on my sc61 and my mitsu flanged O2 housing bolts up perfectly.
definitiveno said:
do they make O2 housings for my application?
Not totally sure. I know they make 4 bolt O2 housings for the garretts if you are gonna run externally gated turbos but I have yet to see for internally gated. You can always make something yourself.
1SloColt said:
Thanks....
Who builds them for my application? What are my options?
I'm very anal about the design of my O2 housings, i'd like to accumulate a list of products that will work so i can research them individually to find the one i think is best......
Anyone looking for this particular housing can call Victory Performance Equipment. I've been making these for the past three years. We've perfected them so that you can use the stock or aftermarket downpipes. No modifications needed.
Scott
Stay tuned....we will soon release our new exhaust manifold to be used in conjunction with our housings. All bolt in.
Yes. IT WILL BOLT UP. What i am trying to say is that the exhaust hole and wastegate hole on the bullseye housing will not match up PERFECTLY with the exhaust/wastegate hole on the mitsu o2 housing. It requires porting and even then they are still off. This is how i remember it when i installed my TO4B. If you take your mitsu gasket and place it on the bullseye housing you should see what i mean. I have'nt been online much, so if there is a revised housing, I wouldnt know.
So When will I get a housing scott?
(readers should check post dates for insight)
    • george bromwell
    • pma1123
    • Sdcryan1
